September 25, 2017, 15:49 |
Wall Y+ for S-A
Lucas Barreto
Rep Power: 8 |
Hi guys,
I am simulating the flow over an aircraft using the S-A turbulence model and I came across a doubt about the Y+. I have seen in a lot of places saying that for tubulence models without wall treatment, my y plus should be approximately 1 on the wall, but is there any problem for it to be less than 1? My wall plus is ranging from 4e-2 to 7e-1, would that be ok? Thanks in advance |
September 26, 2017, 06:34 |
Lower than 1 is even better. You should also have a certain number of points (5-10 or more) within the viscous layer.
Note that below y+ = 5 all fields have a linear behaviour, so going too much below y+=1 is actually an overkill (unless you are doing some grid convergence check). In general, however, SA also allows y+ values higher than that, as its main variable has a linear behaviour also in log region. However, for the other variables you would still be using a wf. |
September 26, 2017, 07:06 |
#3 | |
Lucas Barreto
Rep Power: 8 |
I am doing a mesh convergence study and I am using CD and CL of the aircraft to test it. Both my CD due to viscous and pressure effects are converged, would that mean that my Boundary layer is well represented? I am using a first cell hight of 5e-6 m and 45 points with a 1.2 growth rate. I have used 45 because it gave a smooth transition from the prisms to my tet mesh. |
September 26, 2017, 07:58 |
#4 | |
The minimum suitable grid for your case is just the coarsest one that gave you the final CD value. Obviously, in theory, this does not means that there might not be other quantities which would still vary if you refine the grid. But if your interest is in CD, than you are ok. |
September 26, 2017, 08:42 |
#5 | |
Lucas Barreto
Rep Power: 8 |
I am also checking for continuity, momentum and turbulence (nut) convergence, the first 2 are below 1e-8 and the latter below 1e-6 and my CL has converged in the simulation as well as with respect to the mesh. Hopefully I am getting the right results. |
cfd, s-a, y plus |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Thin Wall Heat Transfer BC for rhoSimpleFoam | swahono | OpenFOAM Running, Solving & CFD | 12 | October 4, 2013 11:49 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 06:23 |
Patches for OpenFOAM 1.7 on MacOS X | gschaider | OpenFOAM Installation | 101 | September 21, 2011 05:37 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
