fluent dynamic mesh (results fluctuate leads to negetive volume) |
October 11, 2017, 01:12 |
#1 | |||
志新高(Zhixin Gao)
Rep Power: 11 |
I'm doing dynamic mesh on a 3D model, and the model is like below. Basically the inner wall rotates along the Y-axis. http://thumbsnap.com/i/nX4AHkBt.png http://thumbsnap.com/CSWQ3Ph2 http://www.dumpt.com/img/links.php?f...cxkg2uyxcs.png I used the Compute_Force-And_Moment macro,and the udf is shown below while in FLUENT i use the smoothing and remeshing methods, and set the inner walls as rigid body Quote:
October 11, 2017, 21:19 |
志新高(Zhixin Gao)
Rep Power: 11 |
I use the 6DOF method today, but the omega still fluctuate
October 12, 2017, 01:35 |
Jigs
Rep Power: 8 |
Use six DOF. and what's your timestep size. Use as small as possible. Also look for CG you've kept.
October 12, 2017, 01:52 |
#4 | ||
志新高(Zhixin Gao)
Rep Power: 11 |
October 15, 2017, 06:36 |
Jaesan Yoon
Rep Power: 8 |
neg. vol is probably coming from geometry change is too quick to remeshing
try smaller rotating or moving speed of body, and remesh for each time step |
October 15, 2017, 06:53 |
志新高(Zhixin Gao)
Rep Power: 11 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Ansys mesh for FLUENT software giving unrealistic results, while GAMBIT mesh is fine | kbhamidipa3 | FLUENT | 0 | November 30, 2012 15:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
