Emptying vessel scenario
Old   October 11, 2017, 22:57
Smile Emptying vessel scenario
DanielH is on a distinguished road
Hi, I am just looking for some assistance on making a gravity induced flow model for a IDDSI test (basically fill the syringe up too 10 ml, then allow that 10 ml to flow out and see how much liquid is loss over 10 sec).
So these are my parameters, transient time, gravity in the -ve Y direction, two phase system (air and a water like fluid with a viscosity= non-Newtonian power law), surface tension of 0.072, syringe openings defined as pressure-outlets (while syringe hole output has a back flow of 1 for fluid), simple solution, patched the entire mesh, and ran the simulation.
The results I get aren't resembling the lab results, any suggestions?
DanielH is offline   Reply With Quote
Water through vessel - Two-way FSI Warlord ANSYS 1 November 20, 2016 07:35
Discharge of Pressure Vessel into Pipe with Regulator gajowni2 System Analysis 0 October 31, 2015 18:57
Initializing a Pressure Vessel jws FLUENT 2 August 26, 2015 03:33
Solid particles in a rotating vessel with 5.7.1 Sandeep CFX 0 May 17, 2005 10:54
Temperature in vessel during throttling process Astrid Main CFD Forum 2 January 31, 2001 02:34
