How to Freeze The Velocity Field, Only Solve DPM+FILM MODEL
Old   October 15, 2017, 08:43
Exclamation How to Freeze The Velocity Field, Only Solve DPM+FILM MODEL
Jeeloong is on a distinguished road
Dear All,
I got one question. So I have a converged solution for dpm+velocity and wall film. The relative changes are negligible.
I am interested to solve only the dpm breakup and injection also the trajectory should also based on one way coupling with the velocity field. And to have dpm impingement on the wall and form a film.
I did the following:
1. SWITCH OFF Equation for (FLOW) & (Turbulence k and omega)
2. DO ONE WAY TURBULENCE COUPLING
3. RUN SIMULATION
when I output my images for the flow field. it still changes.
Please help!
Thanks
Sincerely,
Jee Loong
UK
Jeeloong is offline   Reply With Quote
Old   February 14, 2022, 02:15
rezaeimahdi's Avatar
mahdi
rezaeimahdi is on a distinguished road
I have the same problem with fluent, any solution?
Thanks
rezaeimahdi is offline   Reply With Quote
Old   February 14, 2022, 03:53
mahdi
Well, I found a solution for my case, but not sure if it is correct, needs to investigate a little more.
Actually, I am modelling a steady flow with 1-way coupling for DPM.
In Fluent :
solution> control> Equations
Here you can select which equations you want to solve. In my case, I run a steady case first, and then due to the 1-way coupling, uncheck the flow equations and run the simulation again.
Superimposing 2 Velocity fields For Model inputs in Comsol f.black COMSOL 0 August 2, 2017 09:35
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
