Mass flow outlet or velocity outlet boundary canditions |
October 17, 2017, 14:09 |
amirreza
Rep Power: 8 |
Hi i have a problem with boundery conditions in Fluent.
I have one inlet and 6 outles and for my outlets i have one pressure and for the others i just have flowrates waveform. Is this true that i multiply my waveforms to -1 and set them as flow rate inlet or veleocity ? |
October 18, 2017, 09:18 |
Lucky
Rep Power: 66 |
October 18, 2017, 10:01 |
amirreza
Rep Power: 8 |
You mean i can multiply velocity waveform to -1 and set it at velocity inlet in order to use it velocity outlet?
I can't find BC's discussion which you said |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Net mass flow inlet vs outlet | Nigui28 | FLUENT | 1 | August 12, 2011 10:09 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
