What is the difference between porous jump and porous zone? |
September 20, 2018, 14:28 |
Rep Power: 7 |
What is each one meant for?
September 21, 2018, 11:12 |
Lucky
Rep Power: 66 |
A porous zone applies to cell zones (actual volumes) when you want to model the flow inside the porous region.
The porous jump is a boundary/interface condition. You apply this to surfaces (i.e. infinitesimally thin porous regions) where you want to model only the pressure drop effect but not the detailed 3D flow inside the porous material. It's up to you when you want to use each modeling approach. |
FLUENT porous zone inputs | eishinsnsayshin | FLUENT | 19 | April 17, 2020 04:40 |
How to set up a Porous Jump Zone | pkrishnakumar.er | FLUENT | 3 | August 28, 2018 05:51 |
Porous Jump As Well As Porous Zone | Ammofreak | FLUENT | 1 | October 6, 2014 10:41 |
Porous jump & Porous zone - help needed | Witsarut Jintaworn | FLUENT | 3 | June 14, 2010 22:37 |
Porous jump V.S Porous zone | phxfudong | FLUENT | 1 | October 8, 2009 22:11 |
