October 26, 2017, 16:53 |
Vacuum System Setup
Hi everyone,
I am quite new to Fluent and am currently in the design process of a vacuum lifting system. The current issue I am running into is setting up the simulation for the system. I am trying to find the pressure losses associated with this specific geometry where the 6 bottom lines are suction of about 90kPa. Currently my only design parameter is the pressure as the 6 lines needed to lift a certain weight. I have been trying to model using the inlet conditions as both pressure-inlet and velocity-inlet. I have been setting the outlet condition as outflow since I don't have any requirements yet downline. I was wondering if anyone has some suggestions on the setup for a problem like this or any information on whether my setup is correct or not. It would be greatly appreciated. Thanks. |
Coupling inlet and outlets massfluxes in an enclosed circulation system | NielsB | Main CFD Forum | 1 | October 8, 2015 05:26 |
Simulation of Controlled Leak into Vacuum System | eric.m.tridas | OpenFOAM | 6 | May 6, 2015 09:46 |
Steady state free surface flow in rotational closed system | hilde | CFX | 5 | January 21, 2015 16:47 |
plz rply urgent regrding vof model for my system | garima chaudhary | FLUENT | 1 | July 20, 2007 08:37 |
Need ideas-fuel discharge system | Jan | FLUENT | 1 | October 10, 2006 23:05 |
