Inflation, invalid method
Old   October 27, 2017, 09:19
Default Inflation, invalid method
Darma Yuda
sdarmayuda is on a distinguished road
Hallo,
I'm trying to use the tool 'Inflation'. I have made my mesh and I just need to add some inflation for the boundary layer around the blades. But, I always see under the 'Inflation-Definition-Active-No, Invalid Method'. After I've updated my mesh, a cross instead of a check Symbol beside the inflation on the Outline appeared. (see attachment)
When I tried to use with similar model, but without other Mesh Control-Method, the Inflation can be created. So my question is, can this inflation only be created, when tetrahedrons meshing is used on the Body? Thanks.
Best regards,
Darma Yuda
sdarmayuda is offline   Reply With Quote
[ANSYS Meshing] Problems with creating a hex-uniform MultiZone Mash with Inflation AnnaF ANSYS Meshing & Geometry 4 April 19, 2019 06:24
[ANSYS Meshing] fail to use inflation method saeedakhavan ANSYS Meshing & Geometry 2 August 15, 2016 11:58
Error in compiling new drag model k.farnagh OpenFOAM Programming & Development 13 May 21, 2016 03:08
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
