Velocity inlet BC profile
Old   November 1, 2017, 07:00
Default Velocity inlet BC profile
Antonio
antonio.c is on a distinguished road
I'm having problem with the definition of boundary conditions thorugh profile data.
The .dat file is uploaded well (image attached).
I choose "components" as velocity inlet, then i choose this profile as axial velocity inlet (the same for tangential and radial, with other profiles).
After initializating, when I plot the axial profile (contour plot) the maximum velocity is lower than in the profile boundary condition (around 3 m/s in the boundary, 1.3 m/s in the contour plot)
Why the velocity at the boundary isn't what it sould be?
antonio.c is offline   Reply With Quote
Old   November 1, 2017, 14:22
Antonio
Problem solved, the "r" distance should be specified in meters and not in mm
[swak4Foam] Inlet velocity profile for turbulent pipe flow using swak4Foam zordiack OpenFOAM Community Contributions 5 February 23, 2016 01:52
Setting velocity profile at the inlet using codedFixedValue CTR OpenFOAM Pre-Processing 1 May 20, 2014 12:01
extracting outlet velocity profile from one case to another case's inlet tonggysun OpenFOAM 2 September 13, 2013 04:19
Velocity profile at inlet siw CFX 2 May 3, 2012 09:30
Export & Import Velocity profile as Inlet eRzBeNgEl STAR-CCM+ 6 March 26, 2012 05:16
