Symmetry and total surface heat flux
Old   February 24, 2015, 11:07
Default Symmetry and total surface heat flux
Ontario
CCHunter is on a distinguished road
I am trying to determine the heat transfer coefficient from forced convection for a cylinder in cross flow from a jet.
There is a symmetry condition to split the cylinder and jet in half. I am using a k-epsilon turbulence model. When I look at the total surface heat flux and try to calculate nusselt number from that the results are almost double what they should be. Is the total surface heat flux that fluent calculates calculated from the area modeled (which is half the actual length of the cylinder) or does it take into account that there is a symmetry face and double the overall area of the modeled cylinder?
CCHunter is offline   Reply With Quote
Old   February 26, 2015, 16:58
jsm
JSM
jsm is on a distinguished road
Fluent gives total surface heat flux from the area modeled. You need to double the heat flux if you are using symmetry boundary condition.
With regards,
JSM
jsm is offline   Reply With Quote
Old   November 8, 2017, 04:47
Question heat flux
hamid reza
hamidreza.nb4 is on a distinguished road
i have heat 5W,and my total area is 60*42 mm^2 and use 1 symmetry boundary condition
so should i consider heat flux=5/(60*42*10^-6)=1984 w/m^2 or 5/(60*21*10^-6)=3968 w/m^2 for heat flux BC?
hamidreza.nb4 is offline   Reply With Quote
fluent, symmetry, total surface heat flux
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
