November 22, 2017, 08:25 |
Run calculation
adib
Rep Power: 8 |
can someone explain what is the difference between run calculation using iterations and time steps?
November 22, 2017, 10:22 |
ehsan
Rep Power: 11 |
Dear Adib,
For solving discretized governing equations (i. e. continuity, momentum, energy ...) you need to apply an iterative method. In fact, for steady problems, you can find the solution by iterating while for transient problems you need to use an implicit (or explicit) formulation. It means that you need to iterate in each time step to find the solution in that time and then can advance (in time). |
Quick Question on Calculation Time | Davitt | COMSOL | 0 | January 14, 2016 14:16 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 15:25 |
Error to proceed to Run Calculation | bubuchacha | FLUENT | 2 | February 7, 2013 00:35 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 21:25 |
