December 1, 2017, 07:35 |
UDF for fully developed flow at inlet
John
Hi all
I created a UDF code to make the flow at inlet fully developed for a 3d circular cross section pipe to be modelled in LES. The pipe is 12 inch diameter and the speed is 13 m/s at inlet. I need to verify it and cross check with any similar works done in the past in published papers or reports. Let me know your suggestions. |
December 1, 2017, 14:25 |
Lucky
Rep Power: 66 |
Fully developed laminar or turbulent inlet? Since you mention LES, it seems to suggest turbulent.
The laminar profile is parabolic like and quite doable but the turbulent profile is not known, unless you know it? |
December 1, 2017, 16:09 |
John
It is turbulent flow, what do you mean unknown. I know the flow speed at inlet
UDF parbolic inlet velocity profile for 3D Ractangular channel flow. | srv537 | Fluent UDF and Scheme Programming | 4 | August 10, 2016 09:25 |
Please help me ( udf for regulation the mass flow rate at the inlet ) | swidi | Fluent UDF and Scheme Programming | 0 | July 7, 2015 09:17 |
UDF for inlet mass flow rate | rahulsuresh89 | Fluent UDF and Scheme Programming | 1 | October 16, 2010 17:06 |
How to specify an inlet boundary conditions for a fully developed gas flow in a duct. | legendyxg | FLUENT | 2 | May 11, 2010 07:32 |
UDF for fully developed turbulent pipe flow | Maged | FLUENT | 1 | June 11, 2005 10:37 |
