Mixing Plane error in profile assignement
Old   March 12, 2015, 11:50
Default Mixing Plane error in profile assignement
Dr. Aliosha's Avatar
Dr. Aliosha is on a distinguished road
Dear all,
I'm using FLUENT Mixing Plane.
At first I have performed non reactive simulations... and everything works.
Now I'm trying to perform reactive simulations with FGM model.
When looking for example at mixture fraction or progress variable profiles they are not assigned to the downstream interface. It seams a problem in assigning the correct profile for such variables!
Any suggestion?
Thanks in advance.
Dr. Aliosha is offline   Reply With Quote
Old   March 20, 2015, 06:17
Default Solution...
Ok, I found out why... on the User's Guide!
Limitations:
- The models for species transport and combustion cannot be used with the mixing plane model.
Old   December 19, 2017, 02:17
hassan
mmhmr is on a distinguished road
hi,
did you find any solution to this limitation?
mmhmr is offline   Reply With Quote
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 14:31
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 09:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
Mixing Plane Lee FLUENT 0 August 8, 2003 22:36
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
