January 8, 2018, 13:55 |
FLUENT Radiation models
André
Rep Power: 10 |
I am new to radiation modeling, (even though I have some theoretical knowledge from courses) and my objective is to model a train fire inside a tunnel with convective and radiative heat coming from the fire. The S2S seems like a rather intuitive model but apparently costly in terms of computing power. What do you suggest would be a reasonable model in terms of computational effort to model say 20% of the total heat as radiation? Thank you in advance, Kind regards
Sapere aude! |
January 8, 2018, 20:06 |
Lucky
Rep Power: 66 |
The S2S model isn't that expensive computationally unless you have a lot of surfaces (e.g. as many surfaces as you have mesh cells). But the S2S model does not (inherently) treat participating media, so it is not appropriate for flames. The flame is not a wall of an enclosure. For flames you need to consider how to model participating media.
January 9, 2018, 17:06 |
André
Rep Power: 10 |
Thanks for the response. I am simply modeling the fire as a volumetric heat source for convective fraction, and also a radiation fraction.
However I might use the DO radiation model to do this.
Sapere aude! |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Difference of result betn Fluent & CFX simulation for S2S radiation | njundale | Fluent UDF and Scheme Programming | 0 | November 6, 2012 00:35 |
help!How to set the parameters of the radiation models in the fluent | ChenZhan | FLUENT | 1 | November 5, 2012 11:30 |
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 05:56 |
