ANSYS simulation of fluids in rotational reference systems
Old   January 17, 2018, 10:11
Default ANSYS simulation of fluids in rotational reference systems
Christopher
bamby46 is on a distinguished road
Hello ANSYS-community,
i am very new to this forum but started working withANSYS in order to simulate mircofluidic devices and didnīt find anything that helps unfortunately.
I am considering two open to atmosphere reservoirs connected by a channel that will be rotated. The upper reservoir is filled with a liquid which starts to flow down when rotated. How do i start using ANSYS? Has anybody had a similar problem? The crucial part here is that it is a 3D system where the cetrifugal field induces different forces.
Thank you in advance!
bamby46 is offline   Reply With Quote
ansys, cfd, fluent, rotation
Moving reference frame for turbine simulation Rahl141 STAR-CCM+ 2 December 28, 2017 06:25
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 02:54
-Xlinker --add-needed -Xlinker --no-as-needed NH1994 OpenFOAM Programming & Development 7 December 31, 2014 10:24
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 03:43
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
