How do i modify my Wall y + value for k-epsilon model |
January 26, 2018, 06:15 |
Hells Blade
Rep Power: 8 |
I am trying to simulate the flow of air at at pressure of 6 bar as attached in the figure . I have maximum wall y+ value near the inlet (around 821)
As per fluent documentation the wall y+ function should be in the range of 30 to 300 for k epsilon model When I change my edge sizing from 200 to 100 then wall y + reduces to 774 but still doesnt come in the appropriate range Has anyone faced such a similar issue before Also How does the solver compute wall y + value near the inlet Wall y+ is typicaly the distance between the wall to the first node of boundary layer I have 5 inflation layers across my 3 walls wherein the distance of the first layer is 1e-2 with a growth rate of 1.2 |
January 30, 2018, 09:42 |
Andrea
Rep Power: 16 |
y+ is the non-dimensional distance of the first cell-centre from the wall - the dimensional distance y is non dimensionalised by means of the friction velocity u_tau and the kinematic viscosity as y+ = y*u_tau/nu
Since nu is a physical property of the fluid and u_tau is related to the wall shear stress (and ideally should not depend on your mesh size), you are only left with the option of adjusting y (i.e. the height of your first prism layer) to meet the y+ requirements. As a side comment, from the snapshot of your mesh that you have attached it really looks like you have a very abrupt transition (in terms of volume change) between prisms and core mesh. You might want to change your meshing parameters in order the have a smoother transition between the two regions. Hope this helps, Andrea |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Enhanced wall treatment, low re k-e model, k-w model with low Re correction | junz | FLUENT | 0 | April 21, 2015 15:36 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
