update dynamic mesh failed. Negative cell volume detected |
April 1, 2017, 03:40 |
saif
Rep Power: 9 |
Hi guys,
I am doing simulation of pitching aerofoil(2D). When i am doing the preview mesh motion it gives an error of negative cell volume detected. |
April 4, 2017, 02:02 |
saurabh kumar gupta
Rep Power: 9 |
Try to decrease your time step.
Regards Saurabh |
May 31, 2017, 04:16 |
srcredchi
Rep Power: 9 |
Same problem with my simulation, I decreased time step, changed mesh but nothing worked. Did you get any solution?
May 31, 2017, 04:41 |
@Sandeep Reddy
saif
Rep Power: 9 |
In dynamic mesh ,smoothing settings, select diffusion method and give diffusion parameter as 1. |
May 31, 2017, 04:48 |
#5 | |
srcredchi
Rep Power: 9 |
I already did that. I have attached screen shot, If you don't mind if you have that project with you can you send me that. |
May 31, 2017, 04:50 |
@Sandeep Reddy
saif
Rep Power: 9 |
Your email Id.
May 31, 2017, 04:51 |
srcredchi
Rep Power: 9 |
May 31, 2017, 04:55 |
srcredchi
Rep Power: 9 |
You can be completely sure that I will not use your project file for any personal use. I would just check the way meshing is done. Please send me project file and design, I am really glad you are considering to send me the file. I have submitted 10 posts till now and I never got positive reply other than yours. Thank You very much Saif.
May 31, 2017, 05:11 |
#9 |
srcredchi
Rep Power: 9 |
May 31, 2017, 05:16 |
@Sandeep Reddy
#10 |
saif
Rep Power: 9 |
Its just the case file.
May 31, 2017, 05:18 |
#11 |
srcredchi
Rep Power: 9 |
February 13, 2018, 23:31 |
I get the same error.
#12 |
Dilshan Casseer
Rep Power: 8 |
I get the same error. Update-Dynamic-Mesh failed. Negative cell volume detected. I'm trying to simulate a fan in a room with sliding mesh method. I have not enabled dynamic mesh option. But i get the same error. Any Solution? Thanks in Advance. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
negative cell volume detected in dynamic meshing | engrmansoor2534 | FLUENT | 0 | November 6, 2015 10:34 |
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 05:25 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
