Outflow boundary condition for compressible flow |
February 16, 2018, 01:11 |
Mathew Liebowitz
Rep Power: 8 |
Hi
I am using Fluent to simulate the interaction of a shock with a turbulent boundary layer in a wind tunnel. My inlet boundary condition is a velocity, while the outlet parameters are not known. This means that the ideal boundary condition to be applied at the exit is an "outlet", which extrapolates pressure from within the domain. However, I see that Fluent does not allow you to specify this boundary condition for the density-based solver which I am using. I don't really see that any of the other options are possible, since I do not have data at the exit. Is there any way I can get around this problem? Thanks in advance |
February 16, 2018, 10:15 |
Lucky
Rep Power: 66 |
You mean your outlet is supersonic? Otherwise it needs a BC.
If your outlet is supersonic then just a pressure outlet, use any pressure. |
February 16, 2018, 11:56 |
Mathew Liebowitz
Rep Power: 8 |
Yes, the outlet is expected to be supersonic.
Wouldn't the outlet pressure affect how much the flow is accelerated by? Or would you say that my problem is not fully-specified unless I have this data? |
compressible flow, density based solver, outlet boundary condition |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Mass flow rate boundary condition with negative values | ashtonJ | CFX | 3 | November 26, 2014 05:21 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
