February 15, 2018, 23:37 |
Governing equation
Priyank
Rep Power: 8 |
Hello
I am facing some problem regarding governing equation used by the fluent. Governing equation for the mixture model. 1. In the equation, I think for Incompressible part there should be Kintectic energy part. Means For Incompressible E = h + v2/2 2. From where I can get the derivation of this equation. Hoping for your reply |
February 16, 2018, 11:51 |
Lucky
Rep Power: 66 |
For the incompressible case, the kinetic energy and potential energies are exactly balanced by the mechanical work due to viscous forces. You can find this in Frank White's Viscous Fluid Flow. Or you can compare eq(7) to eq(10) in Energy Equation in OpenFOAM. Then compare eq(14) to 23.4-7.
What has happened here is they have dropped the viscous dissipation term so it is lost how the bulk kinetic energy disappears. |
One question about the discretization of governing equation in OpenFOAM | JinBiao | OpenFOAM Running, Solving & CFD | 1 | December 30, 2011 03:49 |
governing equation of sliding mesh | torn | FLUENT | 1 | August 10, 2006 03:34 |
UDF to add two governing equation?? *NM* | T.K. Yang | FLUENT | 0 | May 9, 2006 03:03 |
UDF to add two governing equation?? | T.K. Yang | FLUENT | 0 | May 9, 2006 02:54 |
Diffusion Equation | izardy amiruddin | Main CFD Forum | 2 | July 4, 2002 08:14 |
