fluent problem
Old   February 21, 2018, 15:31
Default fluent problem
daniel barak
danielbarak is on a distinguished road
Hey guys,
I need to calculate the velocity and temperature field of the flowing case:
t_hot=150 degrees; t_cold=20 degrees; a=10 cm; a1=2 cm ;a2=3 cm
There is a natural convection in gravity field around the black box (that have boundary condition of 0 heat flux all around) I know how to do the geometry and the mesh but I need some help what to fill in fluent conditions.
thank you!
danielbarak is offline   Reply With Quote
Old   February 22, 2018, 11:38
Micael
Micael is on a distinguished road
Following FLUENT tutorials, in order from first one should help a lot. They are well designed for complete beginner.
Micael is offline   Reply With Quote
Problem with Volumetric Reactions in Fluent Kashif Rashid Fluent UDF and Scheme Programming 2 December 28, 2017 00:36
fluent subsonic wing analysis problem fatihcoban FLUENT 0 August 3, 2016 09:41
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM guxin7005 FLUENT 2 June 27, 2016 21:41
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 15:41
