Species mass source
Old   March 8, 2018, 12:46
Default Species mass source
acalado's Avatar
André
acalado is on a distinguished road
Hi everyone.
I am dealing with a problem in which I have 1 velocity inlet, and 2 outlets downstream (like a T junction).
Upstream of the junction I have a species mass source which is being introduced into the flow.
I have a doubt regarding this problem, since when I look at the balance (in+out), it is very close to zero, however I would expect that the mass source would increase the mass flux at the outlets.
Is there any explanation for this? My thoughts are it is a passive scalar, and therefore only follows the flow, and does not add extra mass/volume. Is this plausible?
Thanks in advance!
Sapere aude!
acalado is offline   Reply With Quote
Old   March 9, 2018, 05:54
ehsan
e_cfd is on a distinguished road
I suggest to let the transport equation converges with res<10-6 (if possible). It takes time for the species solution to propagate from the inlet through the domain (even in the steady state problems).
It is better to patch your domain with a reasonable value for the species after initialization and then run your problem.
You can check in different iterations to see if the outlet values are changing.
e_cfd is offline   Reply With Quote
Old   March 9, 2018, 09:13
acalado's Avatar
André
Thanks for the reply e_cfd, however it looks like adding species alone will not change the mass flux.
I tried adding a mass source of 11.3 kg/s and this imbalance shows when I sum the exit and inlet mass flows. The species injection I put was 0.12 kg/s, but before the mass imbalance was about an order of magnitude or two under 0.12, which is just probably due to numerical error.
Thanks anyway!
Sapere aude!
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 17:25
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
