error in adsorber simulation on adsorption chiller
Old   March 30, 2018, 02:47
Default error in adsorber simulation on adsorption chiller
Andre Kurniawan
andrk is on a distinguished road
Hi everyone, would you like to help me to check whats wrong with my step or anything?
This is what I have done...
fluent launcher -> 2D, double presition, parallel 2 processor
time= transient
multiphase = mixture, 2 phases, slip velocity, implicit volume fraction, dispersed interface model, implicit body force
energy = on
viscous = k-epsilon (2 eq)
user defined -> function hooks adjust = 4 selected
I create new material named silica-gel, change density, cp, and thermal conductivity
Phase-1 = water-vapor
Phase-2 = silica-gel (diameter = 0.25 mm)
zone name = silicagel, porous zone (porosity 0.8),enable 1 energy source term (udf sumber_energi)
initialize from inlet
time step 1s for 100 (max 5 iterations/time step)
The geometry is like this...
And this is the UDF code...
#include "udf.h"
#define NO 71.6
#define ALPHA 3080
#define BETA 18.9
#define R 8.31429
/* PERSAMAAN ADSORPSI ISOTERMAL */
DEFINE_ADJUST(adsorpsi_isotermal,domain)
 Thread *t;
 cell_t c;
 real E,A,P;
  thread_loop_c(t,domain) /* loop over cell threads in domain d */
   begin_c_loop(c,t)
     real temp = C_T(c,t); /* temp as temperature cell field variable macro */
     P = C_P(c,t) + RP_Get_Real("operating-pressure");
     E = ALPHA + BETA * temp;
     A = R * temp * log(1.47E9/P);  /* A = RT ln (Po/P) */
     C_UDSI(c,t,0) = NO * exp(-A*A/(E*E));
   end_c_loop(c,t)
/* PERSAMAAN KAPASITAS ADSORPSI */
DEFINE_ADJUST(kapasitas_adsorpsi, domain)
 Thread *t;
 cell_t c;
 real dt;
   begin_c_loop(c,t)
     dt = CURRENT_TIMESTEP;
     C_UDSI(c,t,1)=C_UDSI_M1(c,t,1)+0.15*dt*(C_UDSI_M1(c,t,0)-C_UDSI_M1(c,t,1));
    end_c_loop(c,t)
/* PERSAMAAN KONSERVASI MASSA */
DEFINE_ADJUST(konservasi_massa, domain)
 Thread*t; cell_t c;
      begin_c_loop(c,t)
         C_UDSI(c,t,2)=-0.532224*0.15*(C_UDSI(c,t,0)-C_UDSI(c,t,1));
      end_c_loop(c,t)
/* PERSAMAAN KONSERVASI MASSA SEBELUMNYA DIJADIKAN SOURCE TERM */
DEFINE_SOURCE(src_massa,c,t,dS,eqn)
 dS[eqn]=0.0;
 return C_UDSI_M1(c,t,2);
/* PERSAMAAN PANAS ADSORPSI */
DEFINE_ADJUST(panas_adsorpsi,domain)
 Thread*t;
 cell_t c;
 real p_operating, p_static;
    begin_c_loop(c,t)
     C_UDSI(c,t,3)=ALPHA*sqrt(log(NO/C_UDSI_M1(c,t,0)));
    end_c_loop(c,t)
/* PERSAMAAN ENERGI */
DEFINE_SOURCE(sumber_energi,c,t,dS,eqn)
 real sumber_energi;
 sumber_energi = -C_UDSI_M1(c,t,2)*0.496056352e3*ALPHA*sqrt(log(NO/C_UDSI_M1(c,t,0)));
 dS[eqn] = 0.0;
 return sumber_energi;
Thee error message is The fl process could not be started.
Hope you notice the error, thank you so much
andrk is offline   Reply With Quote
adsorption simulation by fluent! owen FLUENT 2 April 16, 2021 11:09
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 02:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 15:06
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 13:24
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
