April 13, 2018, 01:55 |
Splitting Geometry into Multiple Zones
Max
Rep Power: 8 |
I am attempting to split my geometry into multiple fluid zones. I will have a fluid zone, a porous zone below that, and then another fluid zone below this one. I cannot seem to figure out how to get this to work. I have completed the blocking for this and created 3 bodies for each zone. I'm then associating the relevant blocks to each respective zone. When I do this, it creates error with the mesh. However, if I just do the meshing all with one body, it is just fine. Could anyone help me to figure out how I can split up my domain into 3 zones. I thought by adding these material points and then associating blocks with them it would work simply, but that has not been the case |
April 13, 2018, 04:17 |
creating material points will not help. Create zone names as required and then assign the blocks to the corresponding zone name and check for face association and assign them if they are wrong.
blocking, icem 17, zone separation |
Mirroring / reflecting a geometry in CDF post with multiple planes | imanmirzaii | ANSYS | 0 | July 3, 2015 13:44 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
Mixing Planes with Multiple Downstream Zones | Will Anderson | FLUENT | 0 | November 10, 2010 17:26 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
Multiple import of Geometry in GAMBIT(Catcon Simu) | Amod kumar | FLUENT | 0 | July 21, 2006 23:55 |
