Different turbulence models in different volumes (2) |
April 25, 2018, 09:09 |
Gert-Jan
Rep Power: 27 |
Hi all,
I have a case with two separated volumes A&B. I want to use k-omega-SST in volume A and RSM in volume B. Is that possible in Fluent? If so, can someone tell me how to do that? Regs, Gert-Jan |
April 25, 2018, 12:17 |
Lucky
Rep Power: 65 |
Are your volumes disjoint or connected? If they are disjoint, just run them separately.
The short answer is no, at least not within the same .case file. You'd have to connect them across simulations, which is similar to running them separately. The reason this is not allowed, is because the algorithm to chop up the mesh when you run in parallel doesn't know which physics belongs to each region. Assuming you could chop up the mesh, then you have a load balancing problem that is better avoided. |
April 25, 2018, 17:17 |
Gert-Jan
Rep Power: 27 |
It concerns a case with hot gas and cold water separated by a conducting metal wall.
Fluent allows to run a certain region in Laminar. Also it knows which domain is solid or fluid. Or gas with varying properties versus water with constant properties. Therefore, physics are varying throughout my case anyway. It is possible to setup domains with different physics in CFX via a beta function. I was hoping something similar was available in Fluent. |
different zones, different turbulence models | gmwsy | FLUENT | 5 | June 17, 2020 15:42 |
Different turbulence models in different volumes | Gert-Jan | Fluent Multiphase | 0 | April 25, 2018 06:04 |
Adding turbulence models to (reacting)TwoPhaseEulerFoam | lavdwall | OpenFOAM Running, Solving & CFD | 0 | February 3, 2017 03:04 |
y+ range for turbulence models | babri | FLUENT | 1 | August 30, 2016 17:39 |
in k-epsilon wall function approach high Re turbulence models: question of velocity | romant | OpenFOAM Programming & Development | 6 | May 26, 2016 09:14 |
