chemical reactions won't happen in microcombustor
Old   May 7, 2018, 17:26
Default chemical reactions won't happen in microcombustor
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I am doing a simulation of micro-combustor by importing chemkin mechanism into Fluent. The fuel is methane and air mixture.
Gas phase mechanism is GRI 2.0 and surface mechanism is from deutschmann.
The results of temperature field show the maximum temperature is 550K which is only 50K higher than inlet temperature. Obviously, all exothermic reactions have not happened.
I tried to patch a 2000K high temperature in the whole computation domain to ignite the mixture just like some papers do. however, the results show that it's just like a process of heating the cool incoming mixture and all reactions still can not happen.
I am wondering how can I setup in order to ignite the mixture. Are there any common methods in Fluent to ignite hydrocarbon and air mixtures.
thanks very much!
Weiqiang
Weiqiang Liu is offline   Reply With Quote
Old   May 7, 2018, 21:46
Lucky
In addition to temperature, you need to also patch the reaction progress variable.
Old   May 7, 2018, 21:49
Weiqiang Liu
Hi ,
Thanks very much. I am new to fluent and I cannot very understand what is reaction progress variable. can you give me a more specific hint please?
Weiqiang
How are chemical reactions stored after parsing? DanielW OpenFOAM Programming & Development 3 June 7, 2018 14:39
CO2 diffusion and chemical reactions cletero FLUENT 0 April 23, 2018 10:50
Modelling chemical reactions without considering heat transfer cardioCFD CFX 3 December 16, 2017 18:22
multi phase flow with chemical reactions in one phase Habibfateh OpenFOAM Programming & Development 0 February 10, 2014 07:33
inconsistency in the chemical reactions in Reacting Foam? lfgmarc OpenFOAM Running, Solving & CFD 1 October 10, 2011 11:11
