Heat exchange pipe with a helical vortex promoter: what is causing divergence? |
May 8, 2018, 03:37 |
Haneen JH
I have been trying to run a 3D model representing the evaporation in a heat pipe with a return line inside the pipe. The suggestion to create a vortex promoter was to add a helical spring in the pipe. Experimentally heat extracted from the pipe with the spring was higher than without the spring. Now computationally, the solution always diverges!! I will list the steps I followed and would appreciate it if you can point out a possible error. Meshing: The pipe is 23 mm long, elements reached 1 mill, and want to limit it to that since my computer is not super! However, metrics are good. Model setup: - Multiphysics, Eulerian evaporation-condensation model/ I also tried Boiling model -Viscosity, k-eps, Lee, Implicit / I also tried k-omega Boundary conditions: -Inner wall Temp 103 degrees(saturation) -Outer wall Temp 300 degrees -Pressure Inlet 13 kPa -Pressure Outlet 11 kPa Solution trials: - simple -coupled courant 0.9, 1, 5, default 200 -coupled pseudo transient URF reduced -initialization both hybrid and standard and the list of attempts goes on! I attache the geometry which I really think might be a problem Any suggestions? Thanks in advance |
complex geometry, eulerian multiphase, evaporation condensation, heat pipe |
a possible substitution of heat exchanger module in fluent?! | Sadegh.A | FLUENT | 0 | September 25, 2017 15:49 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Heat trasfer coefficient in a pipe - Fluent | elios | FLUENT | 1 | February 6, 2015 14:18 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
