2D blood flow problem
Old   May 30, 2018, 13:26
Question 2D blood flow problem
Fritz87 is on a distinguished road
Hi everyone,
I am quite new to CFD so I'm sorry if for someone it's a stupid question. I am stuck with a problem with Fluent 16.1, my simulation is just wrong in terms of result. I have spent quite a lot of time on trying to resolve it but I am not able to figure out what is wrong.
The CFD study is: 2D steady state blood flow on a coronary artery (density=1066 kg/m3, viscosity 0.0035 kg/ms). I have gone through all the steps in ansys workbench (from creating the geometry to fluent).
Once in Fluent I prescribe my boundary conditions as pressure-inlet (13333Pa) and pressure outlet (Gauge pressure = 12000Pa), wall no slip conditions. Results of the simulations are shown in the first image attached. Looking at fluxes I noticed the inlet mass flow rate is equal to 1.89 kg/s, the magnitude is completely wrong, 1.89kg/s is not physiological at all, I would have expected mass flow rate of 0.003/0.0025 Kg/s. What is happening here?
It seems like a dimension problem but I defined the mesh to be in mm and checking the scale mesh panel this seems correct.
So, does anyone have an idea of what is going on? or where is the error in my workflow?
Thanks.
Fritz87 is offline   Reply With Quote
A problem of incorrect fluid flow field using Openfoam marialhm OpenFOAM Running, Solving & CFD 25 June 12, 2017 02:34
Having Problem solving 2D supersonic flow around a plug nozzle chrislloyd FLUENT 7 July 22, 2015 13:09
Newbie to compressible, viscous flow. Advice on approach to problem? bzz77 Main CFD Forum 4 December 4, 2012 07:59
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
