How does ANSYS Fluent calculate its enthalpy?
Old   November 28, 2015, 05:46
Exclamation How does ANSYS Fluent calculate its enthalpy?
RebeccaKn92 is on a distinguished road
Hey guys!
I am working with ANSYS Fluent at the moment and now there appeared a question.
I wrote the User-Defined Funtions, one for the density and one for the viscosity - both dependent on the enthalpy. While running the calculation with one of these UDFs I set the other parameter (density or viscosity) constant. All other settings stayed the same in those two calculations.
Now ANSYS Fluent gave me different enthalpy-values in both calculations. Now I am a bit confused because the density and the viscosity respectively should be calculated based on the enthalpy-values and not the other way around.
So can anyone help me and explain to me why I have different enthalpy-values when I just changed the terms for density and viscosity?
Thanks up front!
RebeccaKn92 is offline   Reply With Quote
Old   June 4, 2018, 05:20
DU Shen
tiancaidushen is on a distinguished road
hi, did you figure out the enthalpy calculation in FLUENT?
Originally Posted by RebeccaKn92 View Post
Hey guys!
Thanks up front!
tiancaidushen is offline   Reply With Quote
density, enthalpy, udf, viscosity
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
UDF Defining in ANSYS FLUENT 16.2 in Win 10 Sadegh.A Fluent UDF and Scheme Programming 11 February 15, 2017 14:45
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 05:31
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 03:17
