Oscillating Residuals for flow around an airfoil -ANSYS FLUENT. What should I do? |
June 12, 2018, 07:15 |
öobleck
Rep Power: 8 |
I am using a structured mesh on a D-field having length of 12.5 chord lengths for an airspeed of 33m/s.
I tried both for ke-realisable and kw-sst, the residuals are wildly oscillating. I even tried giving URFs but it didnt work. As the iterations proceed, back flow is occuring and turbulent viscosity ratio is being limited. I am attaching an image of my mesh. |
June 12, 2018, 10:52 |
Rep Power: 10 |
The mesh looks really good, and it seems odd to me that your residuals would be oscillating even after you enabled a turbulence model. Is this a steady-state or transient simulation?
June 12, 2018, 11:08 |
öobleck
Rep Power: 8 |
Its a steady-state simulation.
June 12, 2018, 11:11 |
Rep Power: 10 |
Alright, so you're residuals are all oscillating, but how about other quantities? Did you set any report definitions?
June 13, 2018, 05:35 |
öobleck
Rep Power: 8 |
I am interested in calculating the coefficients of lift, drag and moment. These I defined in the monitors tab. As for the Report Definitions tab, I haven't given anything.
June 13, 2018, 12:11 |
Rep Power: 10 |
Report Definitions are what the Monitor tab monitors. If you are monitoring your solution, you probably already set Report Definitions without even knowing it haha.
When you simulate, I assuming you are looking at the Solution Monitors every iteration to see how they perform. Are they oscillating as well, or do they seem to be okay? |
June 14, 2018, 11:10 |
öobleck
Rep Power: 8 |
I got the problem of back flow and viscosity limitation corrected.
I had missed an edge while defining inlet and outlet. I ran using ke realizable for first order and second order. The first order converged but the second order residuals has become more or less constant. What shall I do? |
June 14, 2018, 11:16 |
Rep Power: 10 |
For that, I would check out the topic of "Convergence" on the forum. It's not the easiest thing to judge, and you might actually be looking at a perfectly good simulation and not even know it. I know that's not the answer you were looking for, but it's the best one I can provide.
April 2, 2024, 14:16 |
#9 | |
fluent 17.2, residual oscillations., structured mesh |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 12:07 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Fluent solving 3D airfoil | rsskarthikeyan | FLUENT | 0 | April 8, 2013 14:06 |
Results are different for Ansys Fluent 14.0 and Fluent 6.3 | syavash | Fluent UDF and Scheme Programming | 1 | February 17, 2013 01:09 |
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge | TWaung | CFX | 2 | February 16, 2010 08:11 |
