Pre-Load Flow Field for Design Point Variationss |
July 3, 2018, 07:59 |
Mario B.
Rep Power: 8 |
when using the Design Point Variations in Workbench, is there a possibility to start with a certain Flow field (.dat File is always the same one) to preinitialize all my different Design Points? And then Fluent should continue calculating all the Variants with the same predefined .dat File? Or is there a way that Fluent always automatically starts a predefined Journal File which is loading the dat-File - when using Parameters? As far as I understood journal Files are just activated manually or by batch - Or will Fluent automatically repeat this for every Design Points? many thanks blerli_91 |
design point, initialization, parameter |
potential flows, helmholtz decomposition and other stuffs | pigna | Main CFD Forum | 1 | October 26, 2017 08:34 |
Far Field flow Prediction | NGH | Main CFD Forum | 1 | August 21, 2012 05:00 |
External flow field. | Moon | FLUENT | 3 | March 5, 2003 10:32 |
Injection of partical into flow field | M.Mahendran | FLUENT | 2 | November 24, 2002 00:54 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
