July 5, 2018, 14:26 |
Profile File Read Issue
Rep Power: 7 |
I have a spatially non-uniform and transient temperature profile that I am trying to apply to a surface. For each time-step I have one profile file and I am setting this solver up so that at the end of each time-step, the solver reads the next time step profile file and then solves it until convergence. To do this, I am using the "Execute Commands" dialog box to load the file after every timestep. However, I am getting an error which states: "file does not exist". This is the code I use to read the profile file:
(ti-menu-load-string (format #f "file read-profile Run35TempProfileTransient.~01d.prof" delta-time)) The variable delta-time is updated to add 0.03 seconds to it's value from the previous timestep. During execution of the program, the string is reading correctly as I get this message: file read-profile Run35TempProfileTransient.0.03.prof Error: read-profile: file does not exist I am not sure how to go about solving this problem. Any help is appreciated. Thanks. |
July 6, 2018, 13:44 |
Lucky
Rep Power: 66 |
Hard to debug without further diving into what else you have done because what you have should work...
July 6, 2018, 20:05 |
Rep Power: 18 |
Are the profile files located in your Fluent folder? Alternatively, you could use the full file path in the command.
July 13, 2018, 10:34 |
Rep Power: 7 |
Turns out that the working directory did not have the profile files loaded in. I just changed the working directory and ran it again. Works fine. Thanks for the help.
file not found, profile files, scheme programming, transient analysis |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
