July 26, 2018, 01:40 |
y+ value for k-epsilon Model
Yoser
Rep Power: 7 |
Hi all
I am working on 3D simulation for my model and used k-ε TM with standard wall function. So,the values of y+ <30. Is it true y+ value that for models mentioned k-epsilon? If not, what is the certain range of y+ value for this TM. Thanks, |
July 26, 2018, 01:43 |
Lucky
Rep Power: 66 |
There are blending functions to make the wall functions play nice so that you don't strictly need to make any y+ criteria except small. But it's nicer to have a globally y+<10 or so such that everything is in the linear regime or avoid the buffer region between 10-30 and make all your y+>30. The y+ criteria isn't actually for the turbulence model but for the wall function being used.
July 26, 2018, 02:05 |
Yoser
Rep Power: 7 |
Thank you to fast reply LuckyTran. You mean my result value for y+ is not true and shoud be in range less than 10.
July 26, 2018, 10:52 |
Lucky
Rep Power: 66 |
Sorry I don't understand your question. y+ is y+, you get what you get. If you want a desired y+ then you need to go back and remesh. My point is that you can have just about any value of y+ and still have quite a reasonable result.
Y+ in k epsilon model for bubble column | ROY4 | CFX | 3 | March 14, 2018 13:50 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
At high Y+ values does the K Omega SST model just behave like the K Epsilon model? | JuPa | CFX | 0 | December 22, 2015 06:44 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
