June 1, 2017, 10:08 |
How to create vacuum in Fluent
Bouras Oussama
Rep Power: 9 |
Hello All, How can vacuum be modeled in Fluent?
Thank you. |
June 1, 2017, 10:12 |
Alex
Rep Power: 47 |
You will have to be waaaay more specific to get a useful answer...
June 1, 2017, 10:20 |
Bouras Oussama
Rep Power: 9 |
I'm sorry .. I want to simulate a power coupler, inside the coupler there is the vacuum and outside there is air so I have to model the convection outside the coupler, the conduction in the material of the coupler and the radiation on the inside So I will use the S2S model for radiation, but when I put nothing inside the coupler Fluent does not want to calculate the radiating faces so I need to model the vacuum thank you |
July 25, 2018, 10:36 |
asdf;lkj
Rep Power: 7 |
Dear, Bouras Oussama
i have same problem i am new in fluent i wanted to create vacuum, if you found he solution request you to assist me |
July 26, 2018, 11:44 |
Mattia
Rep Power: 8 |
Mine it's just a guess but, you could try to set the density of the internal volume very close to zero. I'm not sure how the solver wil behave though...
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
How to create matching mesh zones so that periodic boundary can be created in Fluent | cgoodale1 | STAR-CCM+ | 3 | February 29, 2016 12:34 |
Create a curved surface/ plane in fluent ? | tarkesdora | FLUENT | 1 | September 15, 2014 14:04 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
