August 8, 2018, 06:53 |
conjugate analysis for nozzle
Sai Krishna
Rep Power: 8 |
i have some doubts regrading conjugate analysis.
i am trying to simulate an experiment, in which outside temperature is measured because of the hot gas flow in the simple C&D nozzle. i am taking an axi-symmetric case of the nozzle and used icem cfd for meshing the model, with solid and fluid domains for the fluid and thickness of the nozzle. i have also tried using the one sided wall and giving thickness to the wall in fluent boundary conditions. its a transient analysis, the materials are air and aluminium and with the available inputs i am giving mass flow inlet, and the pressure outlet (exhaust to atmosphere.) but none of them are giving results matching with experiment results. i am not getting where i am getting wrong. help will be greatly appreciated. thank you. |
conjugate analysis, nozzle analysis |
Conjugate Heat Transfer Analysis Problem | redwanamit034 | FLUENT | 1 | June 16, 2015 23:39 |
[ICEM] generating mesh in icem cfd for conjugate analysis | sut | ANSYS Meshing & Geometry | 3 | October 22, 2012 05:31 |
Please help me with conjugate heat transfer analysis | pilsken | FLUENT | 0 | April 21, 2010 08:24 |
2D Conjugate thermal analysis | Prasad | Main CFD Forum | 0 | February 11, 2009 20:34 |
Conjugate Heat Transfer analysis using FLUENT | Ravi Kiran | FLUENT | 0 | February 16, 2006 04:39 |
