Wall Functions & Turbulence Models Query [y plus ranges] |
August 14, 2018, 15:37 |
Rep Power: 8 |
Hi I'm trying to understand the wall functions and turbulence models and the requirements to satisfy each mathematical model via the mesh.
Please correct me if I'm wrong below.
TheMightySpartan |
August 14, 2018, 15:54 |
Lucky
Rep Power: 66 |
Standard wall functions can certainly be used in the y+<10 range. Standard wall functions have a low reynolds number treatment. What's special about enhanced wall functions, is the enhanced part.
Omega models are designed for low y+, but they can tolerate (they use wall functions) for high y+ meshes. Note that k-w SST model is a blended k-e and k-w model that tolerates high and low y+ meshes. y+ < 10 or y+ < 1 is a matter of a lot of personal preference and experience. The point is to be low. The demarcation between viscous sublayer <5 versus linear region <10 only confounds the issue even more. If it matters to you, then do a grid sensitivity study. What's more important than the wall y+ is the total # of grid points you have across the boundary layer and this is not captured by simply plotting y+. |
August 14, 2018, 16:02 |
Rep Power: 8 |
So I should forget about y+ and do mesh sensitivity study?
August 15, 2018, 03:57 |
Lucky
Rep Power: 66 |
You should always do a mesh sensitivity study. Especially if you ever plan on publishing anything.
August 18, 2018, 02:48 |
Rep Power: 8 |
I understand you are talking about the greater mesh region but there must be some kind of rule book regarding wall functions/turbulence model and y+ right?
turbulence models, wall functions, y plus ranges |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Wall boundary conditions for turbulence models | greenleader | OpenFOAM | 2 | May 27, 2013 10:01 |
Two-Layer Models and Wall Functions | sdwijeya | Siemens | 0 | June 18, 2010 15:25 |
Wall functions | tutlhino | OpenFOAM Pre-Processing | 0 | July 2, 2007 05:04 |
abt near wall turbulence wall functions | amv | Main CFD Forum | 0 | May 12, 2003 03:38 |
