Scripts to run fluent in Linux cluster via windows
Old   September 19, 2018, 09:32
Default Scripts to run fluent in Linux cluster via windows
sanjay
sanjaykummar2810 is on a distinguished road
Hello all,
I am facing a problem while using linux cluster to run fluent via windows. In order to run fluent i have wrote two scripts,which you can see in the picture. when i try to run the job using qsub command `qsub fluent_example.job´
Then I got a message as my job has been submitted. But simulation did not start though no one is using the cluster at the moment.
when i have seen the output file i got error as $PBS_O_WORKDIR:undefined varible. Can anyone help me to resolve the error?
Thanks in advance
[ATTACH]65662
Last edited by sanjaykummar2810; September 19, 2018 at 09:34. Reason: picture to keep
sanjaykummar2810 is offline   Reply With Quote
Old   September 19, 2018, 09:44
vesp is on a distinguished road
well, neither did you define the variable in question nor does it seem to be an exported (i.e. globally available) variable.
So go ahead and set it manually to the directory from which you want to execute from.
vesp is offline   Reply With Quote
Old   September 19, 2018, 10:02
sanjay
Hi Vesp,
The specified location below the $PBS_O_WORKDIR is the directory (/share/apps/ansys_inc/v162/fluent) from which I want to execute. So I am actualy manually setting it.
I am slightly new to linux, hence any help in this regard is much appreciated
Old   September 19, 2018, 10:07
just replace the line "cd $PBS_0_WORKDIR"
with
"cd /share/apps/ansys_inc/v162/fluent"
That should work!
Old   September 19, 2018, 10:14
sanjay
Thanks for your fast reply.
I have replaced "cd $PBS_0_WORKDIR" with "cd
/share/apps/ansys_inc/v162/fluent" . Now im getting error as "too many arguments".
Old   September 19, 2018, 10:26
at which command? sounds like you have some typo
Old   September 19, 2018, 10:40
sanjay
im getting error at cd
error message ´cd: Too many arguments´
what do you mean by typo?
Old   September 19, 2018, 10:48
the input to the cd command is wrong, or an enter is missing.
What happens when you remove the line to execute fluent from the job script and just enter "cd XX" (without the "", and replace XX with the dir)
Old   September 19, 2018, 10:55
sanjay
it is still showing cd:too many arguments
Old   September 19, 2018, 11:01
yes, of course, cd takes ONE argument only
you need two lines: one to change to the dir, the second to execute fluent.
as I said, just input "cd XX", where XX is the directory and nothing else
cluster computing, fluent - parallel, linux server
How to run fluent in LINUX Selina FLUENT 26 December 4, 2019 17:25
how to use -ssh w/ Fluent on Linux cluster Bill FLUENT 4 April 2, 2014 00:04
Parallel run of OpenFOAM in linux and windows side by side m2montazari OpenFOAM Running, Solving & CFD 5 June 24, 2011 03:26
FLUENT in Windows Serial and Linux Parallel sham83 FLUENT 0 May 31, 2011 23:38
Is the fluent mesh generate in windows can be used in linux? panda60 OpenFOAM 7 October 19, 2009 11:51
