Vortex Method in Fluent LES
Old   February 24, 2017, 03:46
Smile Vortex Method in Fluent LES
FeiTeng
tengf689 is on a distinguished road
Hi all
I wanna simulate the flow around a cube by using Fluent LES . I know that it is necessary to set fluctuations at Inlet. Now I have some questions:
If I use "vortex method" to generate fluctuations at inlet, how could I give the "Number of Vortices"? (By default, the number of vortices is 190). And how this value influence the result?
By the way , the version of my Fluent is 17.2
Thanks
tengf689 is offline   Reply With Quote
Old   April 16, 2018, 09:42
kingjewel1 is on a distinguished road
Good question. I read in one of ANSYS' LES solution guides that the number of vortices should be N/4 where N=number of inlet grid cells. But how this influences the solution, I'm not sure. Any further thoughts?
kingjewel1 is offline   Reply With Quote
Old   October 2, 2018, 10:19
James Wright
u2berggeist is on a distinguished road
Do you remember what LES solution guide you saw this in kingjewel1?
u2berggeist is offline   Reply With Quote
Old   October 2, 2018, 10:39
Yes it's in "Quick Guide to Settings UP LES-type Simulations" in the ANSYS customer portal Solution: 2039348.
Also here: http://www.tfd.chalmers.se/~lada/com...4_for_Lars.pdf
Old   October 2, 2018, 18:18
James Wright
Thanks!
Since we're posting relevant references, here's a paper I found that goes over the application of VM.
Interesting point, the "Methodology" section of the paper is word-for-word identical to the ANSYS documentation. The lead writer of the paper worked at Fluent, which explains it, but is still pretty unethical (plagiarism does include reproducing your own work with out reference).
fluent, les, vortex generation
LES Vortex Method by Mathey/Sergent MrFrog OpenFOAM Running, Solving & CFD 3 January 20, 2016 07:20
Fluent LES model: grid requirement? dinhanh FLUENT 1 November 11, 2015 12:15
LES in Fluent Goutam FLUENT 0 November 1, 2015 07:49
Vortex Lattice Method: Calculating lift using circulation from vortex ring elements black&gold Main CFD Forum 11 June 26, 2011 23:51
LES using FLUENT sa FLUENT 0 April 2, 2004 18:56
