November 17, 2018, 08:56 |
compressible flow with combustion
MMSQ
Rep Power: 7 |
Respected Sir
I am working on simulation of non premixed combustion of a gas turbine engine afterburner in FLUENT. when I run the simulation for ADIABATIC CASE in non premixed combustion (energy eqn 'OFF' , compressibility effects disabled) the solution is easily converged and reasonable results are obtained. When I enable the compressibility effects in non premixed combustion window followed by recalculating the pdf table, the solution does not proceed beyond 05 iterations with error 'Divergence in AMG solver: pressure correction' I tried to run the solution with species model OFF (combustion OFF), taking Air as ideal gas (compressible + energy Eqn ON), solution is converged and reasonable results are achieved. Problem is encountered only with enabling the compressibility effects while modeling non premixed combustion. Further details are as follow: Mesh size: 6 Million elements (hexahedral + tetrahedral) steady state standard k-epsilon turbulence model radiation: OFF periodic boundary conditions (axisymmetric 30 deg sector) with mass flow air and fuel inlets and pressure outlet solver: Coupled (Courant number 0.3) You are kindly requested to please advice how to proceed with compressibility effects enabled in modeling non premixed combustion. Thanks |
combustion, compressbility effects |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
About compressible flow at low mach | hit | Main CFD Forum | 2 | October 26, 2009 21:21 |
icem 3d mesh for compressible flow with combustion | James | FLUENT | 0 | September 3, 2007 11:46 |
urgent help needed with 2d compressible flow | James | FLUENT | 2 | June 20, 2007 04:22 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
