November 24, 2018, 05:19 |
Pressure Based Coupled
MWRS
Rep Power: 8 |
I have
Pressure inlet Mass flow Rate Outlet How do I achieve convergence? It diverges and stays in continuity -01 Mesh is prefect with y plus less than 1 and min quality 0.36 |
November 24, 2018, 10:53 |
Lucky
Rep Power: 66 |
How is the mesh perfect if the minQuality is less than 1? It's not perfect.
Keep playing with it. Check to make sure your boundary conditions are correct. If it diverges after a few iterations then it could be due to a bad initialization. |
Pressure Inlet Boundary Conditions | Mr.Goodcat | FLUENT | 5 | June 20, 2019 01:47 |
Courant number for pressure based coupled solver | sunilpatil | Fluent UDF and Scheme Programming | 0 | March 28, 2016 22:12 |
Divergence detected in AMG solver: k, epsilon, pressure coupled | Tanjina | FLUENT | 5 | January 13, 2014 10:46 |
incorrect temperature in pressure based solution | Kian | FLUENT | 1 | July 6, 2009 05:59 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
