April 14, 2013, 13:40 |
Mass_Diffusivity: invalid (zero) diffusivity
Parisa
Rep Power: 13 |
Hello my friends,
I am simulating a mixture, using full multi-component mixture and I use kinetic theory. However, I see the following warning that finally leads to stop my simulation: Warning: Mass_Diffusivity: invalid (zero) diffusivity Does anybody know how can I get rid of this annoying problem? I searched a lot and it shouldn't have any relation with the kinetic theory since when I am using a dilute constant value, the temperature limit causes the simulation diverges. Thanks, Parisa |
April 14, 2013, 16:32 |
A-A Azarafza
Rep Power: 14 |
Hi
I think you received the error because you forgot to specify a value for mass diffusivity coefficient for any of the defined species. The default values are zero. Check it out, please.
Regard yours |
April 14, 2013, 16:44 |
Parisa
Rep Power: 13 |
Thanks for your comment, dear friend.
However, there is no option to define individual mass difffusivity for each species. When I use kinetic theory for the mixture, there is no need to set a value for each species diffusivity. Am I right? Where can I set the diffusivity for each species? Thanks, Parisa |
April 14, 2013, 17:37 |
A-A Azarafza
Rep Power: 14 |
Yes, you right, in case of kinetic theory, there's no need for any further settings. I'm sorry I didn't notice to "kinetic theory", I thought you were using "Multicomponent". It's a weird error really! By the way, you can defined the species by using UDS and then define their diffusivity by the options exist in list or by writing your own UDF. I've already done it by writing my own UDF for a mixture of three gases for a fuel cell.
Regard yours |
April 14, 2013, 17:49 |
#5 | |
Parisa
Rep Power: 13 |
Did you use kinetic theory as well? By the way, I am using full-multi component but to calculate the matrix of diffusion coefficients, I use kinetic theory. |
April 14, 2013, 20:42 |
#6 | |
Ernesto
Rep Power: 14 |
April 14, 2013, 20:54 |
Parisa
Rep Power: 13 |
April 14, 2013, 20:55 |
Parisa
Rep Power: 13 |
Valid data, sorry I said valid results.
April 15, 2013, 04:12 |
#9 |
A-A Azarafza
Rep Power: 14 |
Well, respecting to your question, I used Maxwell-Stefan diffusion coefficients of any two species which are dependent on temperature and pressure. They can be calculated according to the empirical correlation based on kinetic theory. But, in my case, I had porous media, so I had to modify it according to percolation theory as well.
Regard yours |
April 15, 2013, 10:06 |
#10 |
Parisa
Rep Power: 13 |
So, you had already the correlations for diffusion coefficients.
But, I don't have them. By the way, I think there is a serious bug in FLUENT thermodynamics database. |
April 15, 2013, 14:18 |
#11 |
A-A Azarafza
Rep Power: 14 |
No I didn't correlate anything myself, just used a correlation from literature. A combined formula based on theory and experimental but based on kinetic theory. It's general not only in my particular case.
Regard yours |
April 15, 2013, 14:32 |
#12 | |
Parisa
Rep Power: 13 |
I am using that one as well. However, I am trying to develop the code by myself to figure out the bug in FLUENT. I am just developing a small and simple code but that is sufficient enough to realize the bug in FLUENT database. |
December 13, 2018, 17:46 |
#13 |
Emerson
Rep Power: 7 |
Hey did you solve your problem?
I'm with the same problem, using ideal gas on density, the kinetic theory on thermal conductivity and viscosity Please someone knows about it? |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Problems building Paraview 3.12 on Gentoo Linux | pajot | OpenFOAM Installation | 11 | April 11, 2013 08:09 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
