December 25, 2018, 06:57 |
Blocking the cyclone apex by air ????
ali
Rep Power: 9 |
I'm running a multi-phase flow of water and air mixture in a cyclone by VOF model. The low-pressure region inside the cyclone is created and air as backflow enters from cyclone's apex but air core diameter is greater than apex diameter (attached image) !!! why??? The water velocity from inlet is 14 m/s while the air velocity from apex is 50 m/s !!! I think maybe it's because of the high air velocity. Please help me to solve it. Thanks in advance |
December 25, 2018, 18:36 |
Alexander
Rep Power: 34 |
show your mesh, may be your mesh is rough
in contours switch off Node Values option best regards |
December 26, 2018, 01:48 |
ali
Rep Power: 9 |
I have changed the mesh to finer mesh before, but the contour has not changed !!!
Node values was also switched off but the contour was not changed !!! (attached image) I can send the case settings to you. Please tell me your comments. Thanks |
Data Center Air conditioning Boundary Condition problem | jaypatel | OpenFOAM | 9 | April 8, 2020 15:04 |
Natural Convection Air Temperature Problem | theBerNii | FLUENT | 1 | November 28, 2016 13:30 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
TRANSIENT HEAT & BOUYANCY IN CONFINED AIR | Carl | CFX | 1 | September 25, 2006 09:48 |
Modelling Industrial cyclone behaviour | Günther Hasse | Main CFD Forum | 3 | October 12, 1999 19:34 |
