December 22, 2018, 09:14 |
how to ignite the mixture
Weiqiang Liu
Rep Power: 9 |
hello all,
I am doing a simulation of methane catalytic combustion in a micro-channel. The inlet temperature is 300K and the solid wall has convection thermal boundary condition with the ambient. Therefore I have to 'ignite' the mixture with some specific methods. what I am doing is patch a high enough temperature to the whole computation domain, like 2000k. However, the results show the whole process is just like a hot region cooled by the cold inlet flow. I am wondering how you guys usually 'ignite' the mixture in fluent combustion simulation. by the way, my model uses chemkin imported mechanism of both gas and surface mechanism. The computation domain is two-dimensional and steady-state. The chemical reaction rate is model by laminar finite rate. thanks very much! weiqiang |
December 22, 2018, 09:56 |
Lucky
Rep Power: 66 |
Depending on the combustion model, patching only the temperature might not be enough. You also need to patch the progress variable and so on also.
December 24, 2018, 23:24 |
#3 | |
Weiqiang Liu
Rep Power: 9 |
Can I ask what is progress variable in my case? To be specific, carbon monoxide and water are burned species, methane and oxygen are unburned species. So to patch a progress variable means to give the burned species an initial mass fraction instead of zero mass fraction? Thanks very much! |
December 25, 2018, 00:59 |
Lucky
Rep Power: 66 |
I don't know... you didn't state what combustion model you are using. Hint! Hint!
Mass fraction is mass fraction. It sounds like you have no clue what a combustion model is. Progress variable is progress variable which delineates burnt/unburnt. Progress variable isn't the only way to model combustion. There's several ways. |
December 25, 2018, 09:02 |
#5 | |
Weiqiang Liu
Rep Power: 9 |
catalytic, chemkin, ignite mixture, methane, patch |
ignite the mixture | Weiqiang Liu | ANSYS | 1 | December 21, 2018 07:40 |
Creating mixture material for gas dissolved in liquid | richard222 | Fluent Multiphase | 0 | May 7, 2016 13:20 |
Mixture model + VOF? | blacksoil2012 | Fluent Multiphase | 2 | February 8, 2014 23:59 |
How to ignite a mixture reactingFoam | Bombolati | OpenFOAM | 1 | April 25, 2013 05:54 |
mixture mass continuity v.s. volumetric mixture continuity in pressure equation | kaifu | OpenFOAM | 0 | June 9, 2011 08:14 |
