External magnetic field data
Like Tree4Likes
  • 1 Post By Robin.Kamenicky
  • 2 Post By Robin.Kamenicky
Old   September 26, 2008, 22:17
Default External magnetic field data
Richard Lee
Hello.
I would like to make an external magnetic field data for MHD module in FLUENT 6.3. The exprimental data is like as below. I have read the FLUENT manual, and tried to make the external magnetic field data many times. But I failed. The magnetic field only is applied along y direction (thickness). X direction is width, and z direction is length.
Please help me how I can make .txt file of external magnetic field data.
Thanks in advance
Distance Distance from center (x direction) from top(mm) z direction 700mm 350mm Center 0 0.075 0.088 0.095 50 0.087 0.102 0.11 100 0.1 0.119 0.129 150 0.111 0.133 0.15 200 0.118 0.143 0.165 250 0.119 0.146 0.17 300 0.111 0.138 0.162 350 0.096 0.118 0.138 400 0.071 0.088 0.103 450 0.038 0.048 0.059 500 0.001 0.002 0.009 550 -0.036 -0.041 -0.043 600 -0.072 -0.086 -0.089 650 -0.102 -0.123 -0.13 700 -0.121 -0.147 -0.155 750 -0.13 -0.159 -0.167 800 -0.129 -0.157 -0.164 850 -0.12 -0.145 -0.15 900 -0.104 -0.123 -0.129 950 -0.086 -0.101 -0.105 1000 -0.071 -0.08 -0.082 1050 -0.057 -0.065 -0.065 1100 -0.049 -0.053 -0.055
Old   September 26, 2008, 22:22
Default Re: External magnetic field data
Richard Lee
The experimental data seems to be seen. Somebody will want to help me, please send me email, I will give you the data.
Old   March 10, 2010, 10:22
niko_04 is on a distinguished road
HEy, i have a problem with magnetic fields on Fluent. i want to be able to alterate the trayectories of ferromagnetic particules ina liquid flow by using a magnetic field, so i can trap them to one side parallel to the flow.
Any advice?
niko_04 is offline   Reply With Quote
Old   November 28, 2016, 11:56
Robin Kamenicky
Robin.Kamenicky is on a distinguished road
Does somebody solve it? I have same poblem in Ansys 17.1
Robin.Kamenicky is offline   Reply With Quote
Old   November 30, 2016, 09:36
Default Solution
Robin Kamenicky
just if anybody would have an interest, I enclose an example of imported file for extenal magnetic field. It works, just do not forget initialize fluent and MHD module before you apply external field. By initialization UDS are set to zero.
Old   December 1, 2016, 04:13
Robin Kamenicky
Sorry one more time,
I have uploaded wrong file, so here it is.
manjunaths likes this.
Old   January 11, 2019, 04:41
Mahjabin najminoori
m.najminoori is on a distinguished road
Best regards,
> Mahjabin Najmi Noori
> Ph. D. student
> Department of Chemical Engineering
> Shahid Bahonar University of Kerman
> Kerman/Iran
> E-mail: _m.najminoori@gmail.com
m.najminoori is offline   Reply With Quote
Old   January 11, 2019, 04:43
Mahjabin najminoori
Hi everyone
I have a 2D (XY) plane and I want to import a magnetic field data in the z-direction (B=B0+bx).
B is a magnetic field in the z-direction, B0 and b are constant values and x is x component direction. I mean, B in z-direction varies with x component linearly.
I am looking forward to hearing from you.
Best regards,
> Ph. D. student
> Kerman/Iran
particles in a localized magnetic field Arturo Ortiz FLUENT 1 March 10, 2010 10:26
magnetic field, workbench alireza ramezani Main CFD Forum 0 March 13, 2008 14:42
How to input Magnetic Field values in ESTER Code? Amit Gupta Phoenics 0 September 21, 2006 13:38
Divergence Free on the Magnetic Field Valdemir Main CFD Forum 1 March 19, 2003 18:33
How to calculate magnetic field in phoenics sun haitao Phoenics 0 January 3, 2002 07:50
