January 6, 2019, 07:05 |
Pressure Tank Simulation
anonymous
i have a project to do and that is simulating a geometry of pipes without inlet and outlet. just have temperature boundary conditions and whole geometry has the pressure of 5000 psi.
whole geometry has been using by the petroleum industry. whenever they want to hydrotest any drilling tool,before using in drilling location they use this contact to test the tool . first, they fill this geometry by water and when the pressure reaches 5k psi they close inlet and just measuring pressure at the other side of the pipe. i attached some pictures of geometry and meshing in Ansys Fluent. my goal is to find pressure distrbution in geometry after spending time and I want to see the effect of environment temperature on pressure distribution. i want some help guys, please. how can i simulate this contact tool? can i simulate this in Ansys Fluent? https://imgur.com/a/0OTC1Do |
inlet and outlet, pressure, pressure distribution, simulating |
Need Help! High pressure Gas discharge from tank to tank through a pipe | superarthur86 | FLUENT | 2 | June 16, 2017 10:22 |
Tank refuelling simulation | Bisht | STAR-CCM+ | 4 | July 30, 2015 11:02 |
Pressure dissipation problem in bubble simulation (Riemann problem) | ndabir | FLUENT | 0 | June 3, 2015 20:17 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
tank sloshing - getting wrong pressure | enghamed | CFX | 2 | April 26, 2011 22:09 |
