Help to find the current ( fluent)
Old   January 28, 2019, 22:04
Default Help to find the current ( fluent)
Siddharth
siddhu23 is on a distinguished road
Hi folks,
I doing some study in the LED model analysis.
for Input current 200mA(applying as heatflux) i am getting temperature of LED 150℃.(temperature contour -->wall temperature)
I need to find out for 145℃ LED temperature what current i need to apply?
solving Problem in : steady state condition
siddhu23 is offline   Reply With Quote
Old   January 28, 2019, 22:22
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
193?
best regards
AlexanderZ is offline   Reply With Quote
Old   January 28, 2019, 22:29
Siddharth
Originally Posted by AlexanderZ View Post
193?
best regards
No If i reduce just 7mA We wont get 145.
In the problem we need to consider convection,conduction & radiation.
so i am asking how to find in the ansys fluent.
Since for solving the problem takes more time.
any way thank you for your response.
Old   January 30, 2019, 10:45
Lucky
Just some clues.
You can use a DEFINE_PROFILE udf macro to define a variable that contains the vaule of the heat flux and apply this as the boundary condition. You can initialize this with 200 mA, or 193, or 192, or something.
Then you can use a DEFINE_ADJUST udf macro to change the heat flux based on some programmable logic.
Not clear to me is your objective function. You have to make a parameter out of this somehow.
Honestly I would probably just do it manually.
Need Help to find a flow in fluent. rrahman CFD Freelancers 1 May 6, 2016 07:10
Get Maxwell ansoft results in ansys workbench and find the flow velocity in Fluent, i rrahman FLUENT 0 April 16, 2016 22:11
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
How to find the equation for Heat Transfer Flux in Fluent?? rohitjvbibin FLUENT 0 October 26, 2010 06:50
