[Sponsors] | |||||
Rep Power: 8 ![]() |
hi everyone,
i have a problem in ANSYS FLUENT V.18 i want to solve a UDS in a domain. i start from an under relaxaition of 0.1 for UDS and in some steps make that to 1. my problem is that for every under relaxation my answers differ from each other! for examlpe when i set UR to 0.2 and LET THE SOLUTION TO CONVERGE (ie. every control point and RESIDUALS are CONSTANT FROM THAT TIME) the answers are COMPLETELY DIFFERENT from the answers i get from UR of 0.2, 0.5 etc. and my results are correct when i set the UR on 1! please help me. thank u. |
Lucky
Rep Power: 68 ![]() ![]() ![]() |
Details? Steady? Transient?
What's a control point? Do you monitor the uds per iteration? All the residuals are constant? But the residual for the uds you should be able to see change. Well of course changing the urf changes the solution. But it is odd that the converged solution is different. Which hints that your solution isn't converged. Which actually hints that you have a numerical oscillation somewhere. |
thanks for your answer,
my simulation is a 2D-Axisymetric-steady. i track "average UDS magnitude" and "maximum UDS magnitude" (per iteration) on several lines in my zone as control points and all of them converge to a different value for every URF!it means that they become straight lines and don't change anymore! but when i increase the URF they sharply change! until i set the URF to 1 and get the correct value! |
Lucky
Just for debugging purposes. Freeze all the equations except the UDS and do the same test. Freezing the other solvers freezes the coupling and dependency of the UDS solution on any of the other equations and let's you confirm that the UDS urf is the issue and not the coupling with other equations (which is always an issue).
yes i did as u said! first i let the flow equations to be completely converge and residuals dropped to e-10! then i solved only the UDS equation and like before for different URF for UDS i got different answers
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Lets talk about relaxation factor optimization | chriss85 | OpenFOAM Running, Solving & CFD | 36 | April 3, 2025 16:45 |
| Suitable range of relaxation factor for VOF boiling cases? | manupp | STAR-CCM+ | 1 | February 4, 2020 07:07 |
| About equation relaxation | chriss85 | OpenFOAM Running, Solving & CFD | 1 | May 2, 2017 20:52 |
| Relaxation and convergence | sammi | Phoenics | 0 | March 20, 2008 04:32 |
| Question on adjusting relaxation factor | CFD Rookie | Main CFD Forum | 3 | January 26, 2004 15:37 |
