Enclosure Error- Operation would result in non-manifold bodies |
February 5, 2019, 12:45 |
Colin Thompson
I am currently modelling a geothermal earth air heat exchanger entering a room (a box). There is then a vent on the other side of the room that is attached to a solar chimney which will accelerate the air out the house.
I have modelled so far in design modeller the house attached to geothermal pipes. I was looking to test a simulation at this stage but have come across the enclosure error. As I am modelling the heat transfer to the air through the pipes and then the mixing in the room I need to create an enclosure as a fluid domain. I was hoping to then do a boolean subtraction to leave me with the domain of air to be meshed. Any advise on how to proceed would be appreciated! |
enclosure.air.default, energy equation, fluent, non-manifold |
[ANSYS Meshing] Boolean creation error - operation would result in non-manifold bodies | thefinalyearkid | ANSYS Meshing & Geometry | 21 | April 8, 2022 16:48 |
Operation would result in non-manifold bodies Error | Synchronous | FLUENT | 8 | June 15, 2017 18:11 |
[ANSYS Meshing] Two bodies, same settings, wrong result. Please help us | StudentinANSYS | ANSYS Meshing & Geometry | 2 | February 10, 2017 04:46 |
[DesignModeler] [ANSYS Geometry] Error: Operation would result in non-manifold bodies | -roberto | ANSYS Meshing & Geometry | 0 | April 10, 2015 06:33 |
not getting result for natural convection in a triangular enclosure | sandeep_mtech | ANSYS Meshing & Geometry | 1 | August 8, 2010 01:50 |
