Eddy viscosity VS Turbulent viscosity
Like Tree5Likes
  • 1 Post By Shayankhan
  • 2 Post By LuckyTran
  • 1 Post By vinerm
  • 1 Post By LuckyTran
Old   February 26, 2019, 21:24
Default Eddy viscosity VS Turbulent viscosity
Naveed
Shayankhan is on a distinguished road
Greetings members,
I want to investigate eddy viscosity (m2/s) in Fluent. But, I can find the turbulent viscosity in Fluent with units "kg/m-s".
Is the turbulent viscosity similar to that of eddy viscosity ?? Or should I convert it using the density of fluid ?? Please help. Thank you.
tariq likes this.
Shayankhan is offline   Reply With Quote
Old   February 27, 2019, 09:53
Lucky
Turbulent and eddy viscosity are the same thing. In your case, it's clear that you need to divide the turbulent viscosity from Fluent by the density to get the thingy that you want. I wouldn't call this the eddy viscosity (because it doesn't have units of viscosity) but eddy diffusivity (having the same units as diffusivity). Anyway, what you decide to call it is up to you.
Shayankhan and AbdelFree02 like this.
Old   February 27, 2019, 20:52
Naveed
Thank you for the kind response.
Old   February 20, 2020, 10:37
Santiago Lopez Castano
Santiago is on a distinguished road
What you say is not true! Eddy Difussivity refers to scalar turbulence. Eddy viscosity in the Incompressible world is presented as m2/s, corresponding to the kinematic viscosity, which is \nu = \mu/\rho
FLUENT looves putting particular names for things, just to add confusion.
Santiago is offline   Reply With Quote
Old   February 20, 2020, 10:44
Lucky
Everything in incompressible world is presented in per rho units. Even mass flux. It's just a preference. It's not Fluent's fault, everybody has their own way of doing things.
Again, eddy viscosity having units of m2/s doesn't have units of viscosity, just like mass flux doesn't have units of mass flux in incompressible world.
Old   February 20, 2020, 11:50
Default Viscosity
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Eddy viscosity models are, well, models. And the way these models model the turbulence (instead of simulate, which is done by LES and DNS) is by adding an extra diffusion due to the turbulence, which is significantly higher (within the turbulent region) than the molecular diffusion. So, the apparent viscosity of a fluid in a turbulent flow is higher than its molecular viscosity. A fluid behaves as a highly viscous fluid when turbulent, hence, requiring extra energy to flow.
Now, eddy viscosity is just a number that quantifies the diffusion of a field, such as, momentum or thermal energy or a component, due to the turbulence. And unit for a diffusion coefficient is same for all fields.
tariq likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 25, 2021, 06:26
Default eddy viscosity? momentum diffusivity?
none
starz is on a distinguished road
Originally Posted by Shayankhan View Post
Greetings members,
I have one more question, so is eddy viscosity = momentum diffusivity?
starz is offline   Reply With Quote
Old   April 25, 2021, 18:47
Lucky
No. Momentum diffusivity is the molecular viscosity divided by density. It is a material/molecular property.
Eddy viscosity is a flow property. It is a coefficient in the linear relation between the strain rate tensor and the Reynolds stress tensor.
tariq likes this.
Old   May 2, 2021, 09:00
none
Thanks for your kind answer! Sorry that I did not express it clearly. I think what you mean is molecular momentum diffusivity. I was want to ask if eddy viscosity = turbulent momentum diffusivity?
I just saw this term in a few papers, e.g.:A study of interunit dispersion around multistory buildings with single-sided ventilation under different wind directions. The authors mentioned that: "In the simulation of dispersion using RANS models, the turbulent Schmidt number (Sct) has a significant impact on the calculation of concentration equation (Tominaga and Stathopoulos, 2007). This number is defined as the ratio of turbulent momentum diffusivity to concentration diffusivity."
I suppose "turbulent momentum diffusivity" means "eddy viscosity"?
eddy viscosity, turbulent viscosity
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
What is linear eddy viscosity toboto Main CFD Forum 2 January 12, 2018 18:30
turbulent viscosity limited to viscosity ratio Alex_B FLUENT 16 September 12, 2012 13:17
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 10:02
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
