February 26, 2019, 21:24 |
Eddy viscosity VS Turbulent viscosity
Naveed
Rep Power: 9 |
Greetings members,
I want to investigate eddy viscosity (m2/s) in Fluent. But, I can find the turbulent viscosity in Fluent with units "kg/m-s". Is the turbulent viscosity similar to that of eddy viscosity ?? Or should I convert it using the density of fluid ?? Please help. Thank you. |
February 27, 2019, 09:53 |
Lucky
Rep Power: 66 |
Turbulent and eddy viscosity are the same thing. In your case, it's clear that you need to divide the turbulent viscosity from Fluent by the density to get the thingy that you want. I wouldn't call this the eddy viscosity (because it doesn't have units of viscosity) but eddy diffusivity (having the same units as diffusivity). Anyway, what you decide to call it is up to you.
February 27, 2019, 20:52 |
#3 | |
Naveed
Rep Power: 9 |
February 20, 2020, 10:37 |
#4 | |
Santiago Lopez Castano
FLUENT looves putting particular names for things, just to add confusion. |
February 20, 2020, 10:44 |
Lucky
Rep Power: 66 |
Everything in incompressible world is presented in per rho units. Even mass flux. It's just a preference. It's not Fluent's fault, everybody has their own way of doing things.
Again, eddy viscosity having units of m2/s doesn't have units of viscosity, just like mass flux doesn't have units of mass flux in incompressible world. |
February 20, 2020, 11:50 |
Viscosity
Eddy viscosity models are, well, models. And the way these models model the turbulence (instead of simulate, which is done by LES and DNS) is by adding an extra diffusion due to the turbulence, which is significantly higher (within the turbulent region) than the molecular diffusion. So, the apparent viscosity of a fluid in a turbulent flow is higher than its molecular viscosity. A fluid behaves as a highly viscous fluid when turbulent, hence, requiring extra energy to flow.
Now, eddy viscosity is just a number that quantifies the diffusion of a field, such as, momentum or thermal energy or a component, due to the turbulence. And unit for a diffusion coefficient is same for all fields.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
April 25, 2021, 06:26 |
eddy viscosity? momentum diffusivity?
#7 | |
none
Rep Power: 9 |
April 25, 2021, 18:47 |
#8 | |
Lucky
Rep Power: 66 |
No. Momentum diffusivity is the molecular viscosity divided by density. It is a material/molecular property. Eddy viscosity is a flow property. It is a coefficient in the linear relation between the strain rate tensor and the Reynolds stress tensor. |
May 2, 2021, 09:00 |
#9 | |
none
Rep Power: 9 |
I just saw this term in a few papers, e.g.:A study of interunit dispersion around multistory buildings with single-sided ventilation under different wind directions. The authors mentioned that: "In the simulation of dispersion using RANS models, the turbulent Schmidt number (Sct) has a significant impact on the calculation of concentration equation (Tominaga and Stathopoulos, 2007). This number is defined as the ratio of turbulent momentum diffusivity to concentration diffusivity." I suppose "turbulent momentum diffusivity" means "eddy viscosity"? |
eddy viscosity, turbulent viscosity |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
What is linear eddy viscosity | toboto | Main CFD Forum | 2 | January 12, 2018 18:30 |
turbulent viscosity limited to viscosity ratio | Alex_B | FLUENT | 16 | September 12, 2012 13:17 |
Too low temperature at combustor outlet | romekr | FLUENT | 2 | February 6, 2012 10:02 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
