Vortex method - limited no of vortices
Old   March 22, 2019, 18:20
Lightbulb Vortex method - limited no of vortices
Oguzhan
heisenmech is on a distinguished road
Hi everyone,
I've used Vortex Method which is available in FLUENT for initial perturbations for an LES case for a turbulent boundary layer problem with heat transfer.
For the method, the number of vortices need to be defined and in the"Quick Guide to Settings UP LES-type Simulations", it says no of vortices to be set should be one fourth of the no of cell faces on the inlet.
The issue is the max no of vortices Fluent allows me to define is limited to 1000 which is not enough considering the no of faces in my inlet where there are around 31k faces (no of vortices should be around 8k).
I've run the case with 1000 vortices but the results are not promising as the turbulence doesn't seem to be developed quite enough.
Any thoughts?
Thanks.
heisenmech is offline   Reply With Quote
Old   March 23, 2019, 15:21
Oguzhan
Does anyone have any idea??
inlet perturbations, les, synthetic turbulence, vortex, vortex method
Linear-Strength Vortex Unsteady Panel Method (2D) Sonik_87 Main CFD Forum 18 February 23, 2020 09:16
Vortex Particle Method eddykendo OpenFOAM Programming & Development 0 June 23, 2014 01:14
Presenation of vortex strength and velocity concept? fruitkiwi Main CFD Forum 0 September 26, 2012 22:08
Vortex method vs High Reynolds number Weili Main CFD Forum 1 August 4, 2006 01:15
Vortex Particle Method Gerrit Main CFD Forum 3 June 27, 2006 04:22
